peet1
Jan 30, 2016Guide
wipe and restore just / and not /data
Okay, I get that Netgear doesn't support this senerio, but all I want to do is wipe and reinstall the OS on the NAS. I do not want to wipe any data volume. This really shouldn't be all that hard, b...
peet1
Jan 31, 2016Guide
I've got a few installs that I use as backup destinations that have 10-20 TB's of backup data. To keep my backup software happy, I've tweeked the OS more than a little. I have a changelog of virtually everything I've done, but a few of my installs are less than pristine. The data can be backed up and restored, of course, but that process can take days and requires more hardware to be deployed at remote locations. All-in-all, it's a crazy hassle. I've got one or two very-out-of-warranty boxes that I'd like to scrap and start over to make sure they're in a reproducable config.
I'd just like to be able to manage these NAS's more or less like any other server. If something gets screwed up, just wipe and re-setup the OS and leave the data intact.
With the provided tools I don't understand how I'd reinstall completly, consequently why I was thinking imaging or an rsync of a fresh install.
Thanks.Peet
mdgm-ntgr
Jan 31, 2016NETGEAR Employee Retired
If you want to experiment you should
- Verify you can access your data
- Make sure you have another copy of the data (of course there would be the primary copy on e.g. your server if the NAS is the backup destination)
- Download the logs zip file so you still have at least some information on the history since the last factory reset.
This is not something we would recommend or support doing and would have the same implications as using SSH.
