sstillwell's avatar
May 02, 2018
Won't boot, won't boot menu, won't boot USB recovery, WILL boot other OS via USB
Well, the subject says it all.  The unit WAS working, but now won't boot normally, won't boot into the boot menu (hold reset, press power on, wait for boot menu).  All I get is the ReadyNAS text on t...
  • mdgm-ntgr's avatar
    mdgm-ntgr
    May 02, 2018
    Is it recognised properly as a Pro?
    Well if the fans are spinning properly perhaps power it down and check for a build up of dust. This unit would be pretty old by now.
ProSupport for Business
