Infinite
Nov 23, 2010Aspirant
Woot! CrashPlan client running on ReadyNAS Pro
I am very pleased to say that the CrashPlan linux client runs nicely on my ReadyNAS Pro. I expect that any of the ReadyNas Ultra models should be able to run the Java client. I was looking for a ine...
skim32
Aug 08, 2012Tutor
Need some help. I have a ReadyNAS Ultra 4 Plus running the latest Radiator at 4.2.21. I followed the directions to a T except I am running CrashPlan 3.2.1 for linux on my ReadyNAS. The point where I am failing is that I am unable to telnet to localhost on port 4200 from the readynas. I have properly setup my ui.properties file with servicePort=4200. When I try to launch the Desktop Client I get the failure message and if I would like to try the backup. The only problem that I can tell is that when I run the netstat command on my Readynas, I don't see it trying to listen on 4242. It does however listen on 4343. I am on a windows box and made sure I have tunneling setup on my putty settings. I also rebooted both the desktop and readynas. But still it won't listen on 4242. I do however see that it listen on 4243.
*EDIT*
So it turns out that even though I get a connection refused when trying to telnet to localhost on port 4200, the Desktop Client works fine. Has anyone seen this situation?
*EDIT*
