Infinite
Nov 23, 2010Aspirant
Woot! CrashPlan client running on ReadyNAS Pro
I am very pleased to say that the CrashPlan linux client runs nicely on my ReadyNAS Pro. I expect that any of the ReadyNas Ultra models should be able to run the Java client. I was looking for a ine...
Aug 08, 2012Guru - Experienced User
Normally you don't telnet to port 4200. You open putty first, and connect with SSH and log into the NAS. This is on the normal SSH port (22). Putty is also configured to forward (as stated in the instructions) PC port 4200 to the NAS port 4243.
After putty is running and you have logged in, you launch the desktop client.
Is that what you are doing, or something else?
