Infinite
Nov 23, 2010Aspirant
Woot! CrashPlan client running on ReadyNAS Pro
I am very pleased to say that the CrashPlan linux client runs nicely on my ReadyNAS Pro. I expect that any of the ReadyNas Ultra models should be able to run the Java client. I was looking for a ine...
simon0117
Sep 01, 2012Tutor
I have a ReadyNAS Duo 4.1.9 . Following the instructions I seem to have come to a roadblock.
My /etc/apt/sources.list
When I try to install the jre:
jupiter:~# cat /etc/apt/sources.list
deb http://www.readynas.com/packages readynas/
deb http://archive.debian.org/debian sarge main contrib non-free
deb-src http://archive.debian.org/debian sarge main contrib non-free
deb http://archive.debian.org/debian-backports etch-backports main non-free
jupiter:~# apt-get install sun-java6-jre
Reading Package Lists... Done
Building Dependency Tree... Done
Some packages could not be installed. This may mean that you have
requested an impossible situation or if you are using the unstable
distribution that some required packages have not yet been created
or been moved out of Incoming.
Since you only requested a single operation it is extremely likely that
the package is simply not installable and a bug report against
that package should be filed.
The following information may help to resolve the situation:
The following packages have unmet dependencies:
sun-java6-jre: Depends: java-common (>= 0.24) but it is not going to be installed
Depends: sun-java6-bin (= 6-07-3~bpo40+1) but it is not installable or
ia32-sun-java6-bin (= 6-07-3~bpo40+1) but it is not installable
E: Broken packages
jupiter:~# apt-get install sun-java6-bin
Package sun-java6-bin is not available, but is referred to by another package.
This may mean that the package is missing, has been obsoleted, or
is only available from another source
However the following packages replace it:
sun-java6-jre
E: Package sun-java6-bin has no installation candidate
