Infinite
Nov 23, 2010Aspirant
Woot! CrashPlan client running on ReadyNAS Pro
I am very pleased to say that the CrashPlan linux client runs nicely on my ReadyNAS Pro. I expect that any of the ReadyNas Ultra models should be able to run the Java client. I was looking for a ine...
simon0117
Oct 07, 2012Tutor
psindrup wrote:
Does that mean that you can not get the CrashPlan to run on your Readynas Duo at all, or do you just have to follow a different installation procedure?
Nope, couldn't get it to work because I think I can't install Java on the Duo sparc architecture?
