KleintjePils
Jan 27, 2018Aspirant
wrong login credentials?
Hi all, Unfortunately running into problems while setting up my ReadyNas 102. Followed instructions for setup and get as far as "discovery", which doesn't work. Onward to the second option by Raid...
- Jan 28, 2018
It seems strange that a new setup wouldn't accept to the default credentials. You tried the URL I gave above?
Doing either a factory default or an OS reinstall from the boot menu should reset the credential back to admin/password.
KleintjePils
see attached pic for more info.
- JohnCM_SJan 27, 2018NETGEAR Employee Retired
Hi KleintjePils,
Welcome to the Community!
You may try doing an OS re-install so the admin credentials will go back to default. You may visit this link for the procedure on how to access the boot menu and select the OS re-install.
JohnCM_S
NETGEAR Community Team- KleintjePilsJan 27, 2018Aspirant
Hi John,
Thanks for your answer. However, I can't even get to the setup of the Netgear, so I have no OS installed yet...
I'm wondering if a factory default boot would do the trick?
Thnx in advanceKleintjePils
- JohnCM_SJan 28, 2018NETGEAR Employee Retired
Hi KleintjePils,
There should already be an OS installed on that but if there is still no data on the NAS, you can also do the factory default boot.
JohnCM_S
NETGEAR Community Team- StephenBJan 28, 2018Guru - Experienced User
Try https://192.168.1.112/admin
It this is a new setup, use admin for the username and password for the password.
The firmware is extremely old - is this a used NAS?
