adb1
Apr 15, 2015Aspirant
X-RAID and access to data if box fails
I've had 2 Ultra 2 Plus boxes break on me in 4 years. The first time round I put one of the disks in a USB and got the data off as it was basically mirrored. Now I've had the second failure and it'...
Apr 15, 2015Guru - Experienced User
My reply crossed your followup...
adb wrote: Another related question is that if I have the 4 disk unit, is it possible to have two volumes, each with two disks, therefore retaining mirroring?
To add some more information... To do this, insert two disks in the initial install. then switch from xraid to flexraid.
Then install the remaining two disks, and you will have an option to add a second volume.
