adb1
Apr 15, 2015Aspirant
X-RAID and access to data if box fails
I've had 2 Ultra 2 Plus boxes break on me in 4 years. The first time round I put one of the disks in a USB and got the data off as it was basically mirrored. Now I've had the second failure and it'...
Apr 15, 2015Guru - Experienced User
The file system is btrfs - not commonly supported in Windows recovery tools, but readily available on linux boxes. The link I posted above gives some linux commands (from mdgm).
RAID-1 in OS6 will allow you to recover data from either disk in the mirror.
