XtheUnknown
Jun 29, 2020Apprentice
X-RAID expansion and RAID6
Greetings! I have a 6-disk system, configured as RAID-6, with X-RAID turned on. Initally, the unit contained 6x6TB disks. I am now (gradually) replacing them with 8TB drives. My undertstandi...
- Jun 29, 2020
If you are on X-RAID you will have to replace 2 more drives to 8TB in order to expand the volume on RAID6, replacing two of your 6TB to 8TB could have expanded the capacity if you are on RAID5. on Flex-RAID all drives should be replaced first.
right now the extra cap from the 8TB is unused but once 2 more drives are replaced it should go to capacity.
HTH
Marc_V
Jun 29, 2020NETGEAR Employee Retired
HTH
XtheUnknown
Thanks - the referenced article makes it clear.
As I have already replaced 3 drives, I assume you meant I need only replace one more to see an increase?
- Sep 06, 2016Retired_Member
