ilan24
Oct 17, 2020Aspirant
X-RAID horizontal expansion and storage size
Hi everyone, I've been reading up on X-RAID horizontal expansion for my RN314. I have been running a single 3TB HDD for a few years and recently bought another 3TB HDD to expand storage. I ma...
- Oct 18, 2020
ilan24 wrote:
But how, if I add another 3TB after that, will I get that full 3TB as well? Wouldn't that mean that I would be sacrificing redundany somewhere?
You wouldn't be sacrificing redundancy.
With 4 disks, you just end up with 3 data blocks and a corresponding parity block. Like the three disk case, the parity block is the sum (actually xor) of the data blocks. You can still compute the missing bytes if any single disk fails - adding up the three data bytes if the parity byte is missing, or subtracting the remaining data bytes from the parity byte if a data byte is missing.
The expansion process includes re-organizing the pattern of data blocks and recomputing all the parity blocks on the disks.
There is one subtilty - redundancy allows you to reconstruct any missing disk, but if the data (or parity) is corrupted, RAID can't figure out which elements of the data is wrong. So it can't repair actual errors.
ilan24
Thanks for the quick response Steven.
For the most part I get it, and am conscious that I probably don't need to understand the finer details of how it all works. But is the upshot of your explanation that if I have 3 x 3TB HDDs / 4 x 3TB HDDs, I'll have 6TB / 9TB of usable storage, and if one disk fails I'll simply be able to remove it and replace it without any data loss? And the final question would be whether I am losing any more usable storage space when I move from 3 HDDs to 4? In your example I can see how I get 6TB from 3 x 3TB HDDs, but I'm wondering whether I would lose a part of the additional 4th HDD when I added it as well for the redundancy?
Sandshark
Oct 18, 2020Sensei
The basic rule is the total space is the sum of the drives minus the largest. So if you add 2 more 3TBs to the NAS, you'll gain 6TB. And if you add a 3TB and a 6TB, then you'll also only get an additional; 5TB untill the extra 4TB of the 6TB drive has a "mate" for it's redundancy.
There are exceptions if you expand with drives that are not at least as large as the largest one already installed.
- ilan24Oct 18, 2020Aspirant
Thanks Sandshark.
Apologies for this, but I'm still missing something. I understand how adding another 3TB to my existing 2 x 3TB HDDs will get me another 3TB in line with the logic Stephen shared. But how, if I add another 3TB after that, will I get that full 3TB as well? Wouldn't that mean that I would be sacrificing redundany somewhere?
- StephenBOct 18, 2020Guru - Experienced User
- ilan24Oct 18, 2020AspirantThanks so much Stephen and Sandshark - really appreciate the support and this helps a lot!
