jonnymorris98
Dec 21, 2020Tutor
X-RAID or Flex-RAID for Duo v1?
I've just fitted two blank 2TB identical disks (enterprise grade) to my old Duo v1, it merrily started to install X-RAID (and is apparently going to take 9 hours, ouch. Would a RAM upgrade speed thi...
- Dec 21, 2020
With 2 disks, X-RAID will create a RAID-1 as well. So, there is no difference there. In a 2-bay unit RAID-1 would be the recommended raid.
As for the speed... These are old units as you know. The CPU and RAM are very limited. I am not sure if you can upgrade the RAM on these models but even if you could, I am not sure it would make much of a difference given the CPU limitations. I think you just need to wait it out.
rn_enthusiast
Dec 21, 2020Virtuoso
