platini76's avatar
platini76
X-RAID wont' expand after upgrade disks
scenario: xraid2 with os6.1.1
installed on two double disk 500gb
after all is sync I have take off one and install one 3tb on bay2
resync.... all is ok, take off also other 500gb and installed other 3tb...
resync..... all is ok but it won't expand to 3tb????
why? where I am wrong?
thanks as usual for your help.
  • when in the afternoon I had 4.2.24 I don't see this post and only disable snapshots, then I upgrade and on 6.1.1 I cannot ask to support... :D
    now is fine, after a reset complete...
ProSupport for Business
