iawa2k
Oct 17, 2016Aspirant
X-RAID2 Expansion - or lack of
Firmware: 6.6.0 Some time ago I upgraded from an NV+ that had maxed out at it's 4x2TB limit. I backed up my data, bought a shiny new RN104, moved the drives over and restored the data. I have...
- Oct 17, 2016
Someone from Netgear might want to look at the logs, so maybe give them a chance.
One option is to remove the drive (which will degrade it again), and perhaps zero it using vendor tools in a PC, and then reinsert it.
iawa2k
Should I post the logs here? When I went round in circles on the support pages I just led me to a page that said try our knowledge base or post in these forums.
I was wondering if to remove the drive and see if the factory format it in anyway but the others I had purchased from the same manufacturer weren't even initialised (i.e. Completely zeroed).
Is there a way to check for partitions without removing from NAS?
- StephenBOct 17, 2016Guru - Experienced User
iawa2k wrote:
Should I post the logs here?Wait for someone from netgear to ask, and then send them using the info here: http://kb.netgear.com/app/answers/detail/a_id/21543/~/how-do-i-send-all-logs-to-readynas-community-moderators%3F
iawa2k wrote:
Is there a way to check for partitions without removing from NAS?You can look via ssh, but probably not a good option if you don't know how to do that already.
You could switch to flexraid, then remove/reinsert it with the NAS running - with no zeroing. The drive should then show up as not in the array. You can then re-add it to the array from the web ui.
