iawa2k
Oct 17, 2016Aspirant
X-RAID2 Expansion - or lack of
Firmware: 6.6.0 Some time ago I upgraded from an NV+ that had maxed out at it's 4x2TB limit. I backed up my data, bought a shiny new RN104, moved the drives over and restored the data. I have...
- Oct 17, 2016
Someone from Netgear might want to look at the logs, so maybe give them a chance.
One option is to remove the drive (which will degrade it again), and perhaps zero it using vendor tools in a PC, and then reinsert it.
iawa2k
Ah ok thanks. Am comfortable with shell access but will wait for Netgear as I'm not in a mad rush and it's all working ok so not a problem waiting.
In the meantime I may try zeroing as you mentioned and may just help making it degraded by pulling the drive and not from one failing.
mdgm-ntgr
Oct 17, 2016NETGEAR Employee Retired
Well if you want to post some logs in the thread you'd be looking at e.g. mdstat.log
If you can send in the logs zip file (see the Sending Logs link in my sig) that would be good
- iawa2kOct 18, 2016Aspirant
Thanks, I have sent the logs in and below is the mdstat.log readout for completness;
mdstat.log
Personalities : [raid0] [raid1] [raid10] [raid6] [raid5] [raid4]
md126 : active raid5 sdb4[0] sdc4[3] sdd4[2] sda4[1]
5860124736 blocks super 1.2 level 5, 64k chunk, algorithm 2 [4/4] [UUUU]
md127 : active raid5 sda3[0] sdd3[5] sdc3[6] sdb3[4]
5845988352 blocks super 1.2 level 5, 64k chunk, algorithm 2 [4/4] [UUUU]
md1 : active raid6 sda2[0] sdc2[3] sdd2[2] sdb2[1]
1046528 blocks super 1.2 level 6, 512k chunk, algorithm 2 [4/4] [UUUU]
md0 : active raid1 sda1[0] sdd1[5] sdc1[6] sdb1[4]
4190208 blocks super 1.2 [4/4] [UUUU]
unused devices: <none>
/dev/md/0:
Version : 1.2
Creation Time : Sun Jul 19 11:29:12 2015
Raid Level : raid1
Array Size : 4190208 (4.00 GiB 4.29 GB)
Used Dev Size : 4190208 (4.00 GiB 4.29 GB)
Raid Devices : 4
Total Devices : 4
Persistence : Superblock is persistentUpdate Time : Tue Oct 18 09:31:52 2016
State : clean
Active Devices : 4
Working Devices : 4
Failed Devices : 0
Spare Devices : 0Name : 0e3462ae:0 (local to host 0e3462ae)
UUID : 6489314e:62984e45:393f9c86:fd1e14d6
Events : 106205Number Major Minor RaidDevice State
0 8 1 0 active sync /dev/sda1
4 8 17 1 active sync /dev/sdb1
6 8 33 2 active sync /dev/sdc1
5 8 49 3 active sync /dev/sdd1
/dev/md/1:
Version : 1.2
Creation Time : Fri Oct 14 18:41:03 2016
Raid Level : raid6
Array Size : 1046528 (1022.00 MiB 1071.64 MB)
Used Dev Size : 523264 (511.00 MiB 535.82 MB)
Raid Devices : 4
Total Devices : 4
Persistence : Superblock is persistentUpdate Time : Tue Oct 18 09:31:46 2016
State : clean
Active Devices : 4
Working Devices : 4
Failed Devices : 0
Spare Devices : 0Layout : left-symmetric
Chunk Size : 512KName : 0e3462ae:1 (local to host 0e3462ae)
UUID : 37f9dc80:2c264e2f:5c4a85e7:8e1fc013
Events : 19Number Major Minor RaidDevice State
0 8 2 0 active sync /dev/sda2
1 8 18 1 active sync /dev/sdb2
2 8 50 2 active sync /dev/sdd2
3 8 34 3 active sync /dev/sdc2
/dev/md/data-0:
Version : 1.2
Creation Time : Sun Jul 19 11:29:13 2015
Raid Level : raid5
Array Size : 5845988352 (5575.17 GiB 5986.29 GB)
Used Dev Size : 1948662784 (1858.39 GiB 1995.43 GB)
Raid Devices : 4
Total Devices : 4
Persistence : Superblock is persistentUpdate Time : Tue Oct 18 09:31:54 2016
State : clean
Active Devices : 4
Working Devices : 4
Failed Devices : 0
Chunk Size : 64KName : 0e3462ae:data-0 (local to host 0e3462ae)
UUID : 02c0f892:0104f79b:8a172133:0596fcdd
Events : 387225Number Major Minor RaidDevice State
0 8 3 0 active sync /dev/sda3
4 8 19 1 active sync /dev/sdb3
6 8 35 2 active sync /dev/sdc3
5 8 51 3 active sync /dev/sdd3
/dev/md/data-1:
Version : 1.2
Creation Time : Tue Jul 21 18:00:29 2015
Raid Level : raid5
Array Size : 5860124736 (5588.65 GiB 6000.77 GB)
Used Dev Size : 1953374912 (1862.88 GiB 2000.26 GB)
Raid Devices : 4
Total Devices : 4
Persistence : Superblock is persistentUpdate Time : Tue Oct 18 09:31:33 2016
State : clean
Active Devices : 4
Working Devices : 4
Failed Devices : 0
Chunk Size : 64KName : 0e3462ae:data-1 (local to host 0e3462ae)
UUID : 36720040:47536d4d:2f17fa60:2ef8a702
Events : 24680Number Major Minor RaidDevice State
0 8 20 0 active sync /dev/sdb4
1 8 4 1 active sync /dev/sda4
2 8 52 2 active sync /dev/sdd4
3 8 36 3 active sync /dev/sdc4
