datapusher
May 11, 2012Aspirant
XBMC and NV+ question.
Hi all, I know from reading this forum that the NV+ cannot handle Plex. But can it handle XBMC? Right now I am using the NV+ to serve up videos to my xbox 360 over DLNA. However this is not a ...
datapusher
May 13, 2012Aspirant
TeknoJnky wrote: XBMC does not run *on* the nv+, the nas can STORE your media files, and XBMC running on some other device (PC/appletv/whatever), can then access your media directly via SMB.
Yes I am aware that xbmc is a client that runs on another device. I know that the device serves up Dlna. However most of the posts I have seen mention browsing the media directory via smb. So one would assume that since it is Dlna complient, the readynas nv+ can serve up media to a client running xbmc. However, since I don't really see anyone mentioning using Dlna for this, I am curious if there are issues with the nv+'s ability to accomplish what m looking to do.
Can it use Dlna or is it stuck using smb. If both why is smb preferred over the other. How much metadata is lost if using smb.
