tourist
Jan 06, 2013Aspirant
Xfer speeds around 3 MBps :(
Here's my info. First set of results using laptop, second using PC. An obvious issue is that I'm not running over a full Gigabit network, but by my reckoning, the theoretical limit for a 100 Mbps netw...
Jan 09, 2013Guru - Experienced User
~3 MB/s over wireless-g is actually extremely good. You are confusing the link speed (54 mbits) with the throughput. Best achievable throughput of 802.11g is around 22 mbits (see the 802.11g summary here: http://en.wikipedia.org/wiki/IEEE_802.11#802.11g)
If you like your router, you could also add in a gigabit switch (gs605 for instance) - that would speed your wired network up to gigabit speeds if you connect it between the router and your wired ethernet. (wouldn't help the laptop of course).
