laalves1's avatar
laalves1
"XZ-compressed data is corrupt - system halted" after upgrade to 6.5.2 #27451687
Hi all,
Yesterday, I logged into the admin page to do a routine check and noticed that 6.5.2 was available. The system was running 6.5.1. I proceeded to upgrade and it took a loooong time to become available, which eventually it didn't. I went downstairs to check and it was saying its IP was 192.168.70.24 which was very weird since its fixed IP is 192.168.70.100. I decided to reboot it and it got stuck on "Booting...".
Then I created a USB recovery drive and tried the reboot from the USB. Nothing, it just gets stuck on "Booting from external USB". The USB drive LED doesn't even flash.
As this box has a HDMI plug, I connected it to my TV and the result is that it goes through the boot process, BIOS loading and all until it stops with:
And that's it. What can I do?
    • YeZ's avatar
      YeZ
      NETGEAR Expert
      It seems like the NAS does not recognize your USB drive, can you find another USB drive that works to do the USB boot recovery?
  • Hi, I tried with 3 different ones already. Formatted them using the utility itself and created the drives.
    • Skywalker's avatar
      Skywalker
      NETGEAR Expert
      What's the output from HDMI when you do USB recovery?
      • laalves1's avatar
        laalves1
        Hi,
        Exactly the same as without the USB: "XZ-compressed data is corrupt - system halted"
        I have in the meantime escalated this to a support case (#27451687)
  • kohdee's avatar
    kohdee
    Administrator
    What is the console output from when you boot normally?
    • laalves1's avatar
      laalves1
      The same.
      If I try to boot normally, the LCD gets stuck on "Booting...". If I try to boot from a USB, the LCD gets stuck on "Booting from External USB"
      Regarding external display output, both internal or external boot attempts go through BIOS but get stuck on:
      "LINUX 4.06 EDD20121002 Copyright (c) 1994-2012
      Loading kernel........
      Loading initrd.gz......ready.
      - System halted"
  • kohdee's avatar
    kohdee
    Administrator
    I wonder if the boot flash became faulty and then upgrading the OS on the chassis caused significant changes and wrote the data strangely. From my experience, I was able to get into a shell and run some simple commands that confirmed that information for me. The keyboard suggestion might help get you to a prompt to really confirm more of the behavior.
    If your device is still within warranty, it might be possible to persue an RMA replacement of the device.
No content to show
ProSupport for Business
