CHAMRE52's avatar
CHAMRE52
Error login to web interface - Ready NAS Duo RND 2000 v2
Hi. The last 6 months (February-March)I haven't been able to login to the web interface ( http://192.168.0.7/admin )
( Error login to web interface - Ready NAS Duo RND 2000 v2 )
Gets this message, here in English:
" The website cannot provide a secure connection 192.168.0.7 uses an unsupported protocol.
ERR_SSL_VERSION_OR_CIPHER_MISMATCH
There is no support for the protocol
The client and server do not support a common SSL protocol version or cipher suite. "
I have not changed anything, anywhere.
Can access all files via Win 10 prof, but some files/folders cannot be moved or deleted
Have copied everything to SSD M.2 disks
Maybe there is a solution for this. Hope!
Best from Christer in Sweden
  • Hi CHAMRE52,
    And welcome to the NETGEAR Community! 🙂
    Unfortunately, most internet browsers have stopped support for ssl1, which is why you're seeing this message. So you have to use an older browser and disable the "automatic update".
    Currently Pale Moon, should still work with last updates.
    Good day to you,
    Valerie D
    Netgear Team
  • ValerieD's avatar
    ValerieD
    Community Manager
    Hi CHAMRE52,
    Good day to you,
    Valerie D
    Netgear Team
    • CHAMRE52's avatar
      CHAMRE52
      Thanks so much. At last after seven months I have access to the web interface. Pale Moon works fine. Even Swedish language possible
      • ValerieD's avatar
        ValerieD
        Community Manager
        Hi CHAMRE52,
        I'm glad I was able to help you! 😄
        Don't hesitate to come back if you have any other questions.
        Good day to you,
        Valerie D
        Netgear Team
