alinge
May 11, 2020Tutor
EX7320 Nighthawk AC200
NETGEAR Nighthawk X4 AC2200 WiFi Mesh Extender Problems setting upp, connecting to a Orbi RBR50 + Satellite During setup, Extender finds 2.4 & 5 Ghz WiFi from Orbi and manages to set up SSID_2.4GHZ...
ValerieD
May 12, 2020Community Manager
Hello alinge ,
Welcome to the NETGEAR community! :)
Did you try to connect from a computer linked via cable to the extender?
Good day to you,
Valérie D
Netgear team
- alingeMay 12, 2020Tutor
Hello Valérie,
Thanks for welcoming me! I really appreciate any assistance!
I have not tried to connect from a computer linked via cable to the extender!
Thanks,
Arne
- ValerieDMay 13, 2020Community Manager
Hello alinge ,
Then, could you try please and give us a feedback?
Good day to you,
Valérie D
Netgear team- alingeMay 13, 2020Tutor
Hello Valérie,
Sorry about my previous short answer!
I can connect to teh EX7320 from my computer with a direct cable. (As I can with WiFi from a mobile phone to the EX7320 SSIDs set up according to instructions).
But then my computer browser tries to connect to http://192.168.1.250/login.html without success. Error message: "The extendert can't connect to the router".
Is it something I am missing completely?
Arne
- ValerieDMay 14, 2020Community Manager
Hello alinge ,
Ok, so is this happening during the setup or is it after completing the setup that you can't connect?
Good day to you,
Valérie D
Netgear team- alingeMay 14, 2020Tutor
As I understand it the setup works fine!
- Power LED green
- WPS LED green
From a mobile phone, I can connect after a login to the extender.
- Client Link LED goes green
The Router Link LED does no go green. "The extender cannot connect to the router".
(A week ago I managed to set up an old "NETGEAR Universal WiFi Range Extender WN2000RPT" as extender but that one creates an SSID with another name, so that's why I am now trying with the EX7320.)
Best regards,
Arne
