Obram
Jul 20, 2020Aspirant
install and pair multiple EX7320
Hi, is it possible to connect and pair several EX7320 Nighthawk WiFi Mesh Extender AC 2200? What do I have to consider when installing multiple extenders? Is it possible to administrate them in one ...
- Jul 21, 2020
Dear @Obram,
Welcome to the Community!
We do not advise using several WiFi Mesh Extenders in the same network, as this could lead to multiple wireless interferences.
Different EX7320 cannot be managed together from the same UI and they cannot be synced one with the other.
If you need to extend the WiFi coverage in your house with multiple WiFi points, you could have a look at our Orbi WiFi Systems (router + satellites). The Orbi system is specifically designed to create one seamless network, so as you move from room to room, your signal won't drop.
Kind Regards,
Erika
NETGEAR Team
ErikaMa
Jul 21, 2020NETGEAR Employee Retired
Dear @Obram,
Kind Regards,
Erika
NETGEAR Team
Obram
Jul 21, 2020Aspirant
Thanks Erika,
so I got a wrong advise regarding the installation of several EX7320 when I shopped.... :-(
Best,
Roman
