Uffe1959's avatar
Uffe1959
My RN312 is super slow on resync after new disk has been added
After firmware update to 6.10.3 I started to look at the logs and saw increased ATA errors. Since the NAS is 7 years old I thought it might be a good opportunity to start exchange of the disks. I bo...
  • ValerieD's avatar
    Apr 16, 2020
    Hello Uffe1959 ,
    Welcome to the NETGEAR community! :)
    You should make a backup of the data first of all (on another support) as long as you have access to it.
    The errors come from the drives, so the chassis is probably not faulty.
    The sync probably takes so long because there is drive failing there and with the constant read/write operations of the sync the ReadyNAS might struggle if a drive is bad.
    Could you send me the logs via MP, please?
    Have a nice day,
    Valérie D
    Netgear team
