Rhystad's avatar
Rhystad
Nighthawk mesh mk63
It seems like my satelites wont connect to any devices. But only to the router. The devicelist is always empty. Is a bug in new software. It was devices in the satelites device list earlier.
  • PatrycjaG's avatar
    PatrycjaG
    NETGEAR Moderator
    Hello Rhystad,
    Welcome to the Netgear Community!
    Do you have an internet connection on your devices?
    Do you see the MK63's network on the list of available Wifi networks?
    Have you tried to do a reset and a reconfiguration after the firmware update?
    Have a nice day,
    Patrycja
    Netgear Team
      PatrycjaG
      NETGEAR Moderator
      Hello Rhystad,
      Did you try to do a reset and a reconfiguration ?
      If you downgrade the firmware, the issue is resolved?
      Have a nice day,
      Patrycja
      Netgear Team
      • Rhystad's avatar
        Rhystad
        I have rolled back firmware on both satelites, and router to V1.0.6.102_2.0.45
        Now everything is ok again. So the newest firmware is full of bugs. Only one satelite accepted wired connection, but that problem disapeared as well. Netgear have to remove the useless firmware. Bad for business with crap like this..
    • Rhystad's avatar
      Rhystad
      Wifi works. But on the android app, the connected devices list on the satelites do not work on this new firmware. The list is empty on the satelites. And devices connected to satelites is not on the routers device list. So now i have no clue what devices connected to my network. Only the devices that is connected to router apear. My phone is now connected wifi, cant se it..
