Carcaranon
Apr 25, 2024Aspirant
Nighthawk X6 R8000 - OpenVPN
Hi, I have a Nighthawk X6 R8000. Hardware Version R8000 Firmware Version V1.0.4.84_10.1.84 GUI Language Version V1.0.4.80_2.1.49.1 I try to activate OpenVPN so I can access my h...
DamianM
Apr 26, 2024NETGEAR Moderator
Hi Carcaranon,
welcome to the NETGEAR Community!
Could you tell me first, if you had configured the DynDNS? You can find the instructions here.
What is the result, when you are testing the DynDNS connection on the GUI?
With kind regards,
Damian
NETGEAR Team
Carcaranon
Apr 26, 2024Aspirant
Hi, yes I have DynDNS setup and working.
That's also seen since I get error response in the Router when I try to connect. That wouldn't be if I tried to connect to wrong external IP.
- DamianMApr 26, 2024NETGEAR Moderator
Hi Carcaranon,
did you try to restore factory setting for the Router and configure the VPN again?
Does it change something, if you change the security option (OpenVPN) from legacy to insecure?
With kind regards,
Damian
NETGEAR Team- CarcaranonApr 29, 2024AspirantI have tested all possible settings but I still get the same issue.
It will connect but during the handshake it stops working.
/Ronnie- DamianMApr 30, 2024NETGEAR Moderator
Hello @Carcaranon
can you tell me which version of the OpenVPN do you use?
Did you test the VPN with a laptop with WLAN connection?
Best regards,
DamianM
NETGEAR Team
