Carcaranon
Apr 25, 2024Aspirant
Nighthawk X6 R8000 - OpenVPN
Hi, I have a Nighthawk X6 R8000. Hardware Version R8000 Firmware Version V1.0.4.84_10.1.84 GUI Language Version V1.0.4.80_2.1.49.1 I try to activate OpenVPN so I can access my h...
DamianM
Apr 30, 2024NETGEAR Moderator
Hello @Carcaranon
can you tell me which version of the OpenVPN do you use?
Did you test the VPN with a laptop with WLAN connection?
Best regards,
DamianM
NETGEAR Team
Carcaranon
May 06, 2024Aspirant
Hi, the OpenVPN is Android version 3.4.2 (9909)
/Ronnie
- DamianMMay 07, 2024NETGEAR Moderator
Hello @Carcaranon
would it be possible by you to test an older OpenVPN version with an older smartphone?
How does it work with a laptop via WLAN connection?
Best regards,
DamianM
NETGEAR Team
