Tuggarn
Nov 11, 2021Tutor
R8000 nighthawk IP adress reservation not working
Hi, Having problem with making a reservation for my surveilance cams. Want them on static IP so I can record through my SynologyNAS. Have other products reserved since before such as NAS, ext...
- Nov 15, 2021
Hi Simone,
As it looks, I got it to work.
It seems like the system is case sensitive, cause when I added it with big letters, it worked.
Nowhere it says anything about this more than when creating admin account.
But it is solved. Could be great to know for you, and maybe update the manual?
Anyway, thanks for the help
/Magnus Tuggarn
SimonaCa
Nov 11, 2021NETGEAR Employee Retired
Hi Tuggarn,
Welcome to the NETGEAR Community :)
When you try to assign a static IP address to your surveillance cams, do you follow the steps listed on the User Manual?
Simona
NETGEAR Team
Tuggarn
Nov 11, 2021Tutor
Hi Simona,
I’ve done exactly like that. I have reservations since before here.
But when adding a new static IP it does not work anymore.
Any trixs that you know about?
/Magnus “Tuggarn”
/Magnus “Tuggarn”
