Tuggarn's avatar
Tuggarn
Tutor
Nov 11, 2021
R8000 nighthawk IP adress reservation not working
Hi,   Having problem with making a reservation for my surveilance cams. Want them on static IP so I can record through my SynologyNAS.   Have other products reserved since before such as NAS, ext...
  • Tuggarn's avatar
    Tuggarn
    Nov 15, 2021
    Hi Simone,
    As it looks, I got it to work.
    It seems like the system is case sensitive, cause when I added it with big letters, it worked.
    Nowhere it says anything about this more than when creating admin account.
    But it is solved. Could be great to know for you, and maybe update the manual?
    Anyway, thanks for the help
    /Magnus Tuggarn
