tc_vbc
Feb 09, 2021Aspirant
RBR50 WIFI instable V2.7.2.104
Hi My RBR50 (and one satellite, wired) has lately started "rebooting/-starting WIFI. It used to be stable as a rock but now uptime seems to get to max 15-20 minutes then it drops then reactivates ...
IoannisDM
Feb 10, 2021NETGEAR Employee Retired
Hi @tc_vbc,
firstly I want to apologise for my mistake about the languages!
After you installed the latest firmware version 2.7.2.104 did you only try a reboot or a factory reset as well?
It would be recommended for you to perform a reset which in return could cause all the features to be available again.
Mit freundlichen Grüßen,
Ioannis
NETGEAR Team
tc_vbc
Feb 11, 2021Aspirant
Hi,
I have only performed multiple rebots after upgrade, last reboot have kept all fine for appr 24h now :)
If WIFi starts going up and down again I test with factory reset
Thanks for the hint
BR Thomas
