willykte
Jan 02, 2022Aspirant
RBR850/RBS850 サテライトが中継器としてしか動作しない
メッシュwifiとして動作していなく、サテライトが中継器としてしか動作しない ■機器 RBR850(ファームウェア:V4.6.3.16_2.0.51) RBS850(ファームウェア: V4.6.3.16) ■接続方法 RBR850 を 別メーカのルータ(Wifi機能なし)と有線で接続しAPモードで動作 RBR850とRBS850を有線で接続 ルータ ー R...
willykte
Thank you for your reply
I'm in trouble because mesh-wifi isn't working
Satellite only works as a repeater
■Setup
router(no-wifi) <-- wired --> RBR850(V4.6.3.16_2.0.51) :AP mode <-- wired --> RBS850(V4.6.3.16)
1.Change RBR850's SSID and pass from default.
2.Wired connection between RBR850 and RBS850
3.Successful synchronization(Backhaul status is good)
■problem
wifi is working. and i can conect internet. but, RBR850's SSID and RBS850's SSID are different.
RBR850's SSID is the SSID I changed.
RBS850's SSID is default
Isn't it mesh-wifi in ap mode?
Jan 02, 2022Guru - Experienced User
Try syncing the RBS wirelessly first to the RBR. Ensure the RBS is fully sinced to the RBR wirelessly. Check the RBS web page to ensure it's using same SSID name after it's synced. Once fully synced, then plug in the ethernet cable.
Is the RBS directly connected to the back of the RBR or is there a LAN switch in between the RBR and RBS?
What CAT# cable are you using? CAT6 is recommended.
