casperha
Jul 29, 2020Aspirant
Ruckus R320 eth connect S350 Series problem
Serial NumberSystem Object OID 5GL18B5F00588 1.3.6.1.4.1.4526.100.4.53 Model Name Boot Version Software Version GS310TP 1.0.0.1 1.0.0.12 when i plug cat6 cable to ruckus r320...
Weifeng_yang
Jul 30, 2020NETGEAR Employee Retired
How long is you cat6 cable?
Is it possible to swap a cable for trial?
- casperhaJul 30, 2020Aspirant
just 5m...
no too long..
i have change cable also just can detect 100M...
cable pulg in my computer can be 1000M
- Weifeng_yangJul 30, 2020NETGEAR Employee Retired
How is the switch port speed if connected with a gigabit computer or another gigabit switch?
Or loop the cable to 2 ports of GS310TP?
if connect my notebook can be 1000M SPEED
i have test every port also same problem .... can't up to 1000...
