casperha
Jul 29, 2020Aspirant
Ruckus R320 eth connect S350 Series problem
Serial NumberSystem Object OID 5GL18B5F00588 1.3.6.1.4.1.4526.100.4.53 Model Name Boot Version Software Version GS310TP 1.0.0.1 1.0.0.12 when i plug cat6 cable to ruckus r320...
Weifeng_yang
Aug 03, 2020NETGEAR Employee Retired
few more questions from RD. please help to confirm. Thanks
# Have we used the same cable for 3 topologies?
R320 - notebook ->1G well
GS310TP - notebook ->1G well
GS310TP - R320 -> 1G failed, 100M only
# Can we set switch port to forced 1G and not auto neg? In that case will Rukus AP be up with 1G?
# If Rukus AP is using PoE then can we switch to dedicated DC power supply and check whether it comes up with 1G when auto neg is enabled on switch port?
Weifeng_yang
Aug 04, 2020NETGEAR Employee Retired
Engineering team hope to know if the link speed is 100M when R320 powered by POE, and link with 1G when using power adapter.
