lyl1988
Apr 19, 2021Aspirant
Share - RBK753 AP Mode satellite ssid/encryption type/key not consistance with router
I spent two days worked on this issue, finally fixed by manually change satellites nvram. Please check my github readme if you face the same issue. Good luck!! https://github.com/greathappyforest...
liu88534
May 05, 2021Aspirant
Yes, I tried to modify wla and wlh before, but it couldn't take effect
lyl1988
Aug 30, 2021Aspirant
Probably you can try to downgrade your firmware..
I am using firware version: V3.2.16.22_1.4.9 have no problem to commit the change.
- lyl1988Aug 30, 2021Aspirant
If you upgrade to the laest firmware. You probably wont able to telnet..
Please check out the solution from Xcelebrichttps://community.netgear.com/t5/Orbi-AX/RBK750-Series-Firmware-Update-v4-6-3-7/m-p/2131307#M18670
- liu88534Sep 08, 2021Aspirant
3.2.16.22_1.4.9 Can't open telnet. How did you do it?
