lyl1988
Apr 19, 2021Aspirant
Share - RBK753 AP Mode satellite ssid/encryption type/key not consistance with router
I spent two days worked on this issue, finally fixed by manually change satellites nvram. Please check my github readme if you face the same issue. Good luck!! https://github.com/greathappyforest...
lyl1988
Aug 30, 2021Aspirant
Probably you can try to downgrade your firmware..
I am using firware version: V3.2.16.22_1.4.9 have no problem to commit the change.
liu88534
Sep 08, 2021Aspirant
3.2.16.22_1.4.9 Can't open telnet. How did you do it?
