Hi! Gesture control can be a blessings or curse depending on your environment. I periodically get false gesture detections which is annoying. It would be great if there was a way to enable/disab...
Wall252
Sep 06, 2021Aspirant
Just navigate to Settings > System > Gestures . Here, you can enable or disable a number of Gesture settings. Did you find this helpful?
