It's nice that you have choices in sizes but would like to see a larger frame than the original one. The wall transformer/plug needs to be greatly reduced in size. When we had an electrician bur...
schumaku
Feb 15, 2020Guru - Experienced User
The right way to go is to use a built-in power supply with just a "8"or Mickey Mouse or IEC socket on the frame. External power adapters are simply junk and had to hide behind the frame. Netgear does it perfectly right on the bigger Ethernet switches.
