It's nice that you have choices in sizes but would like to see a larger frame than the original one. The wall transformer/plug needs to be greatly reduced in size. When we had an electrician bur...
Jeffgear
Apr 20, 2022Virtuoso
It should be possible to purchase a laptop style power module with the correct DC power output that could be more easily installed in the cavity wall. RS Components are a good source for PSUs.
Also, if the Ethernet interface on the Canvas II supported Power over Ethernet (PoE) then it would be much easier to install and hard wire back to a suitable PoE switch with a single cable. But I suspect the power requirement is higher than PoE supports and most consumers don't have a suitable PoE switch.
