bonnie1man's avatar
bonnie1man
Initiate
Feb 09, 2020
Status:
New
Share uploads
I’d like ability to upload a photo and have it show up on my frame as well as my daughters frame and vice versa
2 Comments
  • KevinJ_K's avatar
    KevinJ_K
    NETGEAR Employee Retired
    Hello bonnie1man,
    Thank you for the feedback. Unfortunately, there is not an option to upload a photo and have it appear on both frames. Are both Meurals connected to the same account?
    The only option to have it appear on both Meurals is to download it manually to each Meural Canvas and create a playlist to store the photo. You can then select the same photo and have it displayed on the Meural screen.
    Kevin K., NETGEAR Meural Community Team
