It is a very unsafe design to have the switch listen to every VLAN that's configured as untagged in one of its physical ports for its web management. It would be a relatively simple change to add a s...
schumaku
Dec 29, 2020Guru - Experienced User
Here again, leaving the absent management VLAN config control undisputed.
The Plus switches are built on non-managed switch cores, with just limited configuration options, and with information available from the core. This is config control is implemented using a tiny 8051 class ucontroller nipping on the switch data stream for handling several features, like NSDT discovery, http, tftp, ...
If things like adding a strict management VLAN or https would be soooooo easy as many of the idea-makers it would have happened years ago already.
PS. Instead of open yet another duplicate idea, one could follow up the existing ones, comment, and vote up...
