As a managed switch with 10Gbe uplink ports it is rather surprising that this switch has not been added to Insight - especially when the GS110TPV3 is supported in Insight and costs half as much as th...
schumaku
Dec 11, 2023Guru - Experienced User
Agree with the usability and flexibility of the GS110EMX deployment and configuration.
Answered a hundred times at least. On one hand, the GS110EMX is built like most smaller Plus switches on an unmanaged, configurable switch core, so it's by far not a managed switch. On the other hand, there are neither the CPU resources, the memory, nor the amount of Flash to dream of Netgear Insight cloud management.
Very different, the recently introduced 8-Port Multi-Gigabit (2.5G) Ethernet Ultra60 PoE++ Smart Switch MS108TUP which is built on the similar platform like the MS108EUP — 8-Port Ultra60 PoE++ Multi-Gigabit (2.5G) Ethernet Plus Switch, including the resources required for the Netgear Insight cloud management, or for the sake of it the MS108UP — 8-Port Ultra60 PoE++ Multi-Gigabit (2.5G) Ethernet Unmanaged Switch - all the are coming with different amount of resources and feature sets, and a different pricing.
