As a managed switch with 10Gbe uplink ports it is rather surprising that this switch has not been added to Insight - especially when the GS110TPV3 is supported in Insight and costs half as much as th...
ijhammoUK
Dec 11, 2023Follower
ah great - its answered 101 times now!
So its a switch with management capabilities, but not a managed switch. Costs twice as much as a GS110TPV3, with less 'manageability" - Netgear sure has strange set of products... Would also be good if you could set the port speed of the 10Gb ports too. GUI allows you to chose 100M or Auto for the port speed options for ports 9 and 10. That's super handy when you are trying to connect it to a fully unmanaged switch that you want to rate limit.
From Netgear website:- GS110EMX 8-Port Gigabit Ethernet Plus Switch with 2 auto-adapt 5-speed networking ports (100M, 1G, 2.5G, 5G, 10G) support. Through an intuitive GUI it provides easy, reliable and affordable connectivity with VLAN, QoS, LAG and IGMP management capabilities.
Thanks for the links - will take a look at those, although I dont really need the PoE.
