As a managed switch with 10Gbe uplink ports it is rather surprising that this switch has not been added to Insight - especially when the GS110TPV3 is supported in Insight and costs half as much as th...
schumaku
Dec 11, 2023Guru - Experienced User
VLAN, QoS, LAG and IGMP management (in my logic more configuration) capabilities are still not making it either a Smart or a Managed Switch. None of all this can be implemented on an unmanaged switch. Management requires a fully managed core,
The IEEE standards are making speed negotiation for copper links for 1 GbE and up mandatory - Netgear does strictly stick to the standards, even if not all vendors agree and stick to the standards.
A GS110TPv3 has (like any other 10-port GbE switch) a non-blocking switching rate of 20Gb/s, the GS110EMX does some 56Gb/s. Not just the switch has more load, also the two MultiGig/10G ports have much higher cost on the BOM, and I have not talked about the higher power dissipation. Sure, the 110TP PoE support with a mere 55W total does also count on the price.
For the product positioning, please kindly look into https://www.netgear.com/business/wired/switches/ for more details. The Plus Switches (Easy configuration, low maintenance switches with QoS, VLANS, PoE capabilities) are clearly positioned between the Unmanaged Switches and the Smart Switches (Increased security, high-bandwidth switches for larger networks from core to edge. VLAN, PoE and ACL controls, the Smart Cloud Switches (adding Insight Managed option to the Smart Switches).
A comparable managed switch eight GbE and two 10G capable (SFP+) ports is in the range of about 1000 USD, it does support stacking, SNMP, full SSH CLI, and much more. Yes, a GS110TPv3 is dirt cheap when comparing - price pre-port pressure from the market is obvious - as it comes with some PoE, SNMP, even Lite CLI.
PS. No, I'm not Netgear - just yet another user, deploying larger amount of Netgear switches in the field.
