As a managed switch with 10Gbe uplink ports it is rather surprising that this switch has not been added to Insight - especially when the GS110TPV3 is supported in Insight and costs half as much as th...
schumaku
Jan 17, 2024Guru - Experienced User
ijhammoUK "Re "The IEEE standards are making speed negotiation for copper links for 1 GbE and up mandatory" Does that mean they only auto-negotiate or have to be able to?"
Mandatory == a "must" feature according to the standards.
ijhammoUK "The 10Gbe ports on the EMX auto-negotiate just fine - but you cant set the speed manually which is a pain if the device you are connecting is one that only auto-negotiates."
Any specific issue or just difficult to understand or dislike an industry-standard link auto-negotiation which takes place?
