As a managed switch with 10Gbe uplink ports it is rather surprising that this switch has not been added to Insight - especially when the GS110TPV3 is supported in Insight and costs half as much as th...
ijhammoUK
Jan 30, 2024Follower
schumaku the auto-negotiation is just fine - nothing to dislike or not understand there. It’s the lack of ability to set the two 10g ports manually to any of the supported speeds. 1g, 2.5g, 5g etc that was a bit of a surprise.
as ErwinL suggested - I will suggest as a feature request
