As a managed switch with 10Gbe uplink ports it is rather surprising that this switch has not been added to Insight - especially when the GS110TPV3 is supported in Insight and costs half as much as th...
schumaku
Jan 30, 2024Guru - Experienced User
This isn't a suprise - just a strictly standards compliance not permitting what you want to achieve. Appears you still don't want to understand what mandatory auto-negotiation means for link speeds faster than 1 Gb/s.
Still lost a little bit for what purpose and even more the reason why you are so desperate to fix the link rates on these MultiGig ports. A 10 GbE port will work, a device supporting max 5 Gb/s or 2.5 Gb/s will perfectly negotiate, just like a pure GbE device.
If the cable quality does not allow the negotiated link rate - fix your cabling.
