Hi,
for a bit quietly work of switch you can add a options to configure fan or give some premade modes to select. The fan can turn on more often and with smaller power. I think that the switch now is a bit loud and it's disturb when it's quiet and only the switch rotating the fan.
No CommentsBe the first to comment
