Greg75
Jan 23, 2018Follower
Add remote reboot capability to WAC104 interface
It would be very usefull to be able to reboot online from the interface especially when remotely managing. Being able to change the wifi power would be great too but this is more complex
Hopefully ...
HotinTN
Jun 26, 2025Fledgling
I agree, it is seriously needed.
Jun 27, 2025Guru - Experienced User
The WAC is EoL so you'll not be seeing any new features for this request forth coming:
https://www.netgear.com/support/product/wac104/
If you need reboot or remote reboot support, find you a remote networkable power switch that you can connect the WAN power adapter too. Then reboot power off or reboot the switch manually.
Good Luck.
