PaddyL
Feb 11, 2019Follower
Status:
New Idea
Adding LAG to VLAN/PortBased/Advanced on JGS524Ev2 (as realized on GS750e)
Dear ladies and gentlemen,
I have several Netgear Switches. Two of them are the GS750E and the JGS524Ev2.
I am using port-based VLANs and wanted to create a 4-Port LAG connection between them.
On the GS750E I create a LAG with 4 ports as port members.
After that I remove the ports that are members of the LAG from the VLAN and add the LAG to the VLAN instead.
the GS750E has FW Version 1.0.0.22.
When I want to do the same on the JGS524Ev2 there is no possibility under "VLAN/port-based/advaced" to add the LAG to the VLAN.
It would be very great if you could realize this feature in the next FW release of the JGS524Ev2. I am just using the latest FW!
Thanks a lot !!
1 Comment
By rule of thumb, on the smaller Smart Managed Plus models you can simply add the LAG individual ports (as added to the LAG) for the VLAN.
It's mainly a simplification in the UI.
