I recommend that Netgear allow the Orbi Pro models to the ability to disable wifi radios at user's option for the following reasons: Simple update for Netgear/Orbi - Currently, Orbi software all...
TSpitzmann
Oct 04, 2022Guide
Indeed, this is a great idea, but I would like to have the setting per Wireless configuration (Wireless 1 ... Wireless 3 / Guest Portal)...
Currently it is a global setting but making it 'local' that would serve turning off undesired bandwidths đ
Example: If you want to integrate your IoTs into your network, you might just want to send them on 2.4 GHz only. In this case on the 'local setting' of 'Wireless 3' turn down the 5 GHz band to 0% and voilĂ - you're done đ
