rhunley's avatar
rhunley
Follower
Feb 09, 2017
Bugfix Request: Increase maximum monthly limit for Traffic Monitor
This in regards to the Traffic Meter monitoring function of the SRX5308 VPN Firewall.  However this would apply to any device in Netgear's product lineup that monitors the amount of IP traffic per month.
Currently the traffic meter can set a monthly traffic limit of up to a maximum of 256000 MB (~250 GB).  However, this is insufficient for those who are using Comcast as an ISP where the limit is set to 1 Terabyte (1024 Gb).
Request that the montly traffic limit setting be adjustable in the Terabyte range.
1 Comment
  • This is marked as fixed and then tells you to suggest that you actually fix it!!  Please fix it instead of telling us to tell you to!
