DSS_SP's avatar
DSS_SP
Follower
Jul 09, 2020
Status:
New Idea
Change the management VLAN to a different one than 1
It would be very interesting to be able to change the management VLAN to a different one than 1 on the GS105E.
BR,
1 Comment
  • schumaku's avatar
    schumaku
    AFAIK no Smart Managed Plus switches (excpet of some 10G ones) have a strict management VLAN - the management processor is reachable from any VLAN.
    For example, in DHCP mode the switch can pick up an IP config from any VLAN's DHCP server.
    All you need is an IP address in the same subnet - regadless of the VLAN the computer is on.
